packinkimber45
- 378
- 3
- May 26, 2006
Boise,
Idaho
Hello guys, I did another compression test on the motor yesterday. Unfortunately the number doesn't look so good. 140/135/120/145. Between high and low, I probably need to rebuild? During the test, there was no indication that cylinders were losing compression on the gauge. I have not done a wet test yet. What other reasons could be for the cylinder being 120 besides rings? Could motor get colder and show different results? I only let the car warm up by letting it idle for a while. Per temp gauge on dash car was warmed up or should I have taken the car for a drive? Reason I didn't is due to car running rough. When I bought the car, the owner told me motor was swapped out on my 90 talon awd. I was told it is a 91-94 turbo 6 bolt motor. It is suppose to be a jdm motor, but owner took off cyclone manifold and jdm valve cover. Is there a way to verify if this motor is in fact a jdm motor? Also is it possible car was swapped with a 6 bolt n/t motor and added a turbo to car? How do I verify that the motor is in fact a "6 bolt turbo motor"? I know how to check for 6 or 7 bolt. I know it is a 6 bolt. Your help would be very much appreciated. Thanks.
Ps.
Hopefully I sell my gsx soon so I can have some funds to work on the car. I wonder if $1300-$1700 is enough to rebuild for a daily driver with goals of 300hp-400whp in the low 13's to high 12's? I already have my stage 1 mods by the way.
Ps.
). if the block is bad, then you would probably need oversized pistons and make the machine shop hone the block, or just rebuild the cylinder walls, and use stock pistons. N/T cars are kinda different though, but i don't think you have a N/A, because otherwise, the compression would be higher, and not that low like yours, the max compression is around 160 for a 1g turbo engine. the only thing that may change, is the block, if it was swapped with an N/A one, the only difference is that it doesn't carry oil sprayers. with 1300-1700$ i would be in the low 12's easly if you have done the stage 1 mods, just use your money wisely dude, and you will get there, also get a chilton's manual, and begin doing the stuff on your own. get a headgasket, rings, and if the block is fine, call it a day. good luck.
