slidewayzka
- 1
- Jul 2, 2006
American Fork,
Utah
i did a search on the mbc install and there is a how to that states use a intake manifold as your mbc pressure source and not off the turbo is that right? because i have my pressure source coming off the jpipe where turbosmarts instructions told me to use. i am still overboosting at what should be a low boost setting.
here's how i have my in cabin mbc installed:
first off its mounted in the engine bay and not in the the drivers compartment
hose from the jpipe that connects to the wastegate actuator has a tee that connects to the lower fitting of the mbc, the upper fitting is open because i was told is was just a vent. sound right to everyone or what? thanks!
