40% tps value at wot
95_Talon_nt
Jul 16, 2004
Lewisburg, Pennsylvania
1990 tsi awd
almost stock afcII, mbc, and boost gauge.
Thought my car was running fine. "A little slow" but thought it was just the weather.
A few days before tps value was 100% @ wot.
Ran my car @the track (first time)
Noticed that my tps value @ wot was only 40%
Took the car to my friends house and had him look under the hood.
when you floor the gas it hits wot. But the pocket logger reads 45-50%
When you wot the throttle body from under the hood it reads 45 - 50%
Tryed 2 tps sensors and both do the same thing 45-50%
Took the sensor off the tb and used a flat head screw driver to move it to the max pos.
Both tps sensors read 45-50%
Check my connection under the hood, and checked all connections in the car, ecu splices for afc. Afc harness.
Any ideas I really though it would be the tps but after trying 2 of them and getting the same value I just dont know anymore.
Tryed searching but all i found was hot to set the idle tps value.
I didnt see anyone having a problem with only 40% tps value.
ANY HELP WOULD BE GREAT!! thanks in advance:dsm:
Not yet i'll try that in a hour when i get off of work. But i took the sensor off the cars tb and moved it to the max and min position with a flat head screw driver and it still gives me the 0% // 45-50% value. :) :dsm: So that shouldn't be an issue correct?
