linkage pictures or info
Talon-96
Banned Member
78
Aug 5, 2006
Hoquiam, Washington
Hey since my 3rg gear only stays in under the pressure of giving it gas, Should I check the cable wires and cable wire bushings? Ok well I was wondering if i could either get some pictures of where those are or advice on where to look. thank you for your time in advance.
Look for your upper radiator hose. They're directly under that. They're long things with rubber boots on them.
They look like this, but with rubber in those holes:
A good way to check is to remove shifter cables off the gear selector levers (on the tranny), but leave them in the braket, have your friend put shifter into '3rd gear' position, then you manually move gear selector levers into third gear (you can guess which way to move them by looking at shifter cable movement), and then look to see if shifter cable reaches far enough, to match gear selector lever, when 3rd gear is selected.
