90GSX17
- 62
- Sep 26, 2005
Raleigh,
North Carolina
So i've been fighting this for about 3-4 months now, I ported the wastegate flapper and it still creeps from 13psi to 16psi. I'm getting sick of it and just found a 1g exhaust manifold with a fitting already made for a 38mm external wastegate on it, i'm thinking of just ditching the interal wastegate, for a external would it be hard to do? Car is stock other than the 3inch turboback,open air filter, and MBC. it's a 93 TSI AWD. Any write-ups on changing wastegates?
. Don the problem with 16psi on the stock fuel system would be needing a fp upgrade, or if you go more then 18psi, you need to upgrade to 550cc injectors, I think thats what your talking about...right?
