Ultimatedsm
- 823
- 27
- Apr 20, 2005
Scarborough,
Hey how are you guys doing? My car has been very loud lately, kind of sounds like a mini diesal truck. I went to the track and managed to pull a 14.4 at 91 mph. My car felt really slow and the boost was set at 10 psi but would hit 15 psi at redline (Creep). My mods are:
FMIC (26x12x3) side to side /w 2.5 inch piping
T-clamps and 4 ply couplers
HKS Mega Flow intake
1G BOV
3 inch turbo back exhaust with 3 inch high flow cat
DSMLINK
14B turbo with the JDM 6 bolt
Tein SS suspension
My logs seemed good as well, got 18 degrees of timing at redline which isn't too bad (Haven't tuned it yet, there was zero knock).
Anyway, today I installed my t-clamps and 4 ply couplers, no more blow outs
, and when I started the car, I noticed the loud truck noise was coming from the exhaust manifold/o2 housing area. I put my hand right infront of the o2 housing connects to the turbo and I felt a lot of air rushing out. I reved it and even more air was rushing out. Well, that explains my shitty performance. I think the bolts that connect the o2 housing to the hot side of the turbo came loose a bit, and one of the turbo bolts from where the exhaust manifold connects to the turbo was loose as well (You can turn it with your hand).
I am just wondering, what kind of performance loss I might of gotten from this stupidness. Thank you guys,
Ultimatedsm,
1G BOV
DSMLINK
Tein SS suspension
, and when I started the car, I noticed the loud truck noise was coming from the exhaust manifold/o2 housing area. I put my hand right infront of the o2 housing connects to the turbo and I felt a lot of air rushing out. I reved it and even more air was rushing out. Well, that explains my shitty performance. I think the bolts that connect the o2 housing to the hot side of the turbo came loose a bit, and one of the turbo bolts from where the exhaust manifold connects to the turbo was loose as well (You can turn it with your hand). I am just wondering, what kind of performance loss I might of gotten from this stupidness. Thank you guys,
Ultimatedsm,
