which catback exhuast system is deep BUT NOT!! LOuD!!
HKS Hi-power, i never see to many people on here that have these, sounds awsome, nice and deep, only loud at WOT. I'd put that into consideration
Yes i have an hks high power catback, and its not too loud. It has a resinator in addition to the muffler. It sounds awsome.
I don't know if any exhaust will be not load enough for you. But, I'll have to suggest the thermal as well.
My custom magnaflow it pops and gurgles it's loud but that's because of no cat/test pipe. if I had one on there it would be much much quieter
eclipseism said:
Im debateing from HKS HI POWER OR THE HKS CARBon ti HMMMMZZZZZZZZ
Up to you, they probably both sound pretty close to each other, if you want to save a couple bucks get the Hi-power, if you like the look of the Carbon Ti then get that one.
it also depends on a couple things. i have the carbon ti off of the apex 3" downpipe and its quiet as hell. but i have a dump pipe for the wastegate off the o2 housing, as you can expect, its loud! however it is not the exhaust that is loud. i am 3 inch from the turbo back, no cat, no res., and you can barely hear it. if you plan on running a cat. and/or a res. it will definetly get quieter and a bit smoother.
Any strait throw style exhaust is gonna be loud at WOT!
I like my Magnaflow. It sounds pretty rumble-y. I do have a HighFlow CAT too, which helps get rid of the little tinks, and raspy sounds. The combo works good to make a deep smooth rumble. (FORA 4BANGER ANYWAY) :D
Anybody have a clue what kind of exhaust I have?
I'ts stainless steel. Has a real deep sound. Almost quieter than stock at idle. Not as loud as an Apexi at WOT.
The whole system from the o2 pipe back was replaced right before I bought the car. I forgot to ask what kind it was, but he paid over 1k for it. It's completely welded, not a single clamp and has a high flow 2.5 inch cat. No resonater.
It's kind of has a cat's eye shape and the exit area is really thick.
Kinda looks like an Apexi WS2, is there any badges or anything on it?
Full 3" SS turboback VRS with the O2 eliminator and a high-flow 3" catalytic all the way baby!!!
Trust me. Quieter and deeper than any of the other ones except the Thermal R&D. They are owned by magnaflow, and the VRS is a magnaflow muffler as well, so they are "on par".
Nothing on it from underneath or on the sides.
I don't think it's the ws2 because the ws2 has visible welds on the outside.
At least judging from online pics anyway...
Actually I just read the description of it and the pic they show must be different from the actual because it stated..
"The oval canister houses a newly designed rolled tip for an extremely high class finish"
So the pic they have must be a genereal representation...
Thanx guys...
