Looking for turbo similar to hy35
TurboTwoStrokes
2
Jan 24, 2006
Glencoe, Minnesota
Looking for a turbo that is spec'd similar to a holset hy35. Hy35's are hard to find, so just wondering if there are other turbo's close to the same in compressor and turbine size. I believe hy35's have a 9cm2 turbine housing, not sure on the compressor side. Not looking for a hx35 because a 12cm2 housing will have too much lag.
I would have put this in the turbo system tech forum, but apparently new members can only post questions here. Also this isn't for a dsm application.
Thanks for any info in advance.
Do you know the AR or flowrate on that turbo? Theres so many turbos out there and the only thing that came up when I searched for that turbo, they were all in diesals.
All i know about holset turbo's are that the hy35's have a 9cm2 (.65 a/r) turbine housing and came stock on 2001 dodge cummins pickups with an auto tranny, and that hx35's have a 12cm2 turbine housing and came on dodge cummins pickups from like 94-now. I'll do some more looking and see if I can find more info on them.
Since the hy35's only came on the 2001 auto tranny pickups, they are hard to find so I'm trying to find a similar turbo, like a garrett t3/t4 if thats about the same for example.
i would call some local junk yards i know were i live the guy said they had 3 2001 cummins and 2 auto that were complete still but thats in maine, but im sure a local junk yard near you would have something like that
