Buschur FPR vs B&M FPR vs Aeromotive FPR
Prez
241
2
Jul 18, 2003
Des Moines, Iowa
OK whats the difference and what would you reccoemend. Besides price differance what is a benifit of the Buschur over B&M.
People say the B&M is just a modifier and you can only raise fuel pressure. Well if you never want to go below stock why buy a complete FPR like Buschur?
I'm going with 550CC injectors, 255 pump, and probably the Buschur FPR on a EVO III 16G with 20-24 PSI and a Megasquirt Standalone. Should be sufficient enuff yes or no?
Whats up, I personally have the bushur. I love it. One thing that should be pointed out is that the aeromotive and bushur are the same but the bushur just has an custom machined lower section that fits to a 1gen fuel rail. The regular aeromotive sx requires -an lines and fittings and a special adapter to the fuel rail. The B&M just sucks compared to these though. Your right about it not being able to lower pressure and that is what you want with 255 walbro. I would say go with the bushur one, if for nothing else at least for ease of installation and cleanliness under the hood.
Kent
PS where do you get the megasuirts for dsms?
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
