'90 turbo tb on a 93 n/t/turbo Converison , how do i run the vaccum lines?
4g63forlife
71
Aug 11, 2004
woodbridge, New Jersey
I just converted my non-turbo talon to a jdm 4g63t and the throttle body only had one vaccum line on the cyclone intake , which i ditched for a ported 1g intake manifold, anyway one of my friends had a working '90 throttle body for the turbo model so i figured i could use it , i did all the wiring for the ISSC and the TPS , but as for the vaccum lines where do they go? I also have an aftermarket B.O.V from TurboXs type -h RFL , where does that line for it go?
tps wires where the same color , i had to solder it , i don't know what the connector was like it was cut. As for the ISSC the wires are the same colors but the connector was a little different so i took a es connector and hooked it up to the wires.
