BrokenTsi
- 1,831
- 36
- May 3, 2003
Rome,
New York
got a p roblem. I installed a walbro 255, aeromotive FPR, and pte 680's. The only problem i have are the 680's. Yes, i got all new seals in the head and the rail. The injectors never seal. They are very loose. #3 always leaks under boost leak test. And its always tearing up fuel rail seals. No matter what I do, it always leaks at the injectors under a boost leak test. I got the "FIC" styel injector seals for PTE injectors brand new and they are installed. WTF?! Yes, base fuel pressure is set correctly and the fuel rail is tight. Should I get an aftermarket fuel rail? Do they fit better?
, it happens every day. check out nate from straightlinespecialties.com. He runs 10.80's no nitrous all day long. 10's in the 1/8th is like a 16.0.
