Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 09-27-2002, 12:06 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: benleyd19tx is an unknown
What should I shop for?
I'm completely stock, just got a new clutch installed... so I need to start the buildup process to burn it up.... j/k But seriously....my goals aren't anything more than low 13's at the moment (havn't seen the boost bug hangin' around yet, but 'm sure he's watching and waiting ). I race almost entirely on the streets, so this is my only real area of concern. I also have a FWD (make sure to keep this in mind). I'm going to score the widest tires I can fit on a 16" rim in a 40-45 profile +adjustable shocks and some beefy springs so that's out. As for what size exhaust/dp/o2 and Turbo to get for mid-upper range power(I won't be able to get much low end power to the ground for a while, so it has to be in the high range) I don't know how to go. The main concern here is keeping my traction... and then I'll catch up to them afterwards. So what do you guys suggest?
____________________________
1990 Gs-t
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 09-27-2002, 04:59 AM   #2 (permalink)
Proven Member
90tsiawd's Avatar
Region: Southeast
Reputation: 90tsiawd is more helpful than not
The key to traction in a fwd is drag radials and a diff.
As for the rest i would start with a rewired fuel pump, hacked mas, 3 inch turbo back(just so you dont have to upgrade later) mbc, upper intake pipe and a boost gauge / a/f gauge. You can keep the 14b for now. Get the other stuff first.
there is also alot of good reading out there
www.dsm.org
www.vfac.com
staged upgrades at
www.buschurracing.com
www.turbotrix.com
hope this helps you get started. Good luck and have fun with it.
Tom N.
11.4 @ 119 (evo316g)
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12004304 seconds (72.71% PHP - 27.29% MySQL) with 9 queries
