bormtlm
- Jul 27, 2011
roy,
Utah
i a 97 gst when got the car it ran just fine a little sluggish it had a few problem the exhaust mani gasket as leaking an turbo gasket replaced the gaskets while at it i got bigger turbo put it all in hooked everything back up started the car ran just like before it sat aa couple days went back out to it started right up an turned right off after three sec like turned the key off but didnt it starts up evey time the same an right back off it will rev up right when you start it for three sec then shut off an cant figure out what could be wrong if you could help it would be awesome
