You can also remove the rear CV axles to check if you have LSD or not. If you see through the gears the other side of the diff, you have LSD. If there's your diff pin blocking the hole in center, you don't have LSD
From stock state, only 1990-1991 1GA DSMs had 3 Bolt rear diffs, 1992-1994 1GBs got the 4 Bolts. Most were LSDs, nut not all. You can also inspect your driver's door sill for an OEM ticker in orange color that says: This vehicle is equipped with a limited slip rear differential. I've searched a lot like you for knowing all that
