which Vacuum line should I Put the T on to connect Boost Gauge?
ewood05
Mar 29, 2010
CanalWinchester, Ohio
I have a 420a turbo setup and want to reconnect my boost gauge. The problem is I dont know which vacuum line to splice and put a T on. I already have everything else set up. Ill post pictures to show setup ina sec. I the "area" in which i should splice. The right line in the intersection goes to the BOV. the left goes to fuel regulator as you can see. The middle line goes to the fuel rail.
Thanks for help in advance !
You want to plug the boost gauge line directly to the intake manifold, If not directly to it then T it in to a line closest to the intake manifold.
The most accurate places you can get the proper readings from will be directly from the intake manifold, or the Fuel Pressure Regulator vacuum line.
Well i had it connected and the gauge stopped working and i was busy and ignored it. but i got it connected thankfully ! good to know my 15lbs are doing their job and i can see it
A: Please don't make multiple threads. I don't care how impatient you are. You could have spent the time searching for the answer and probably found it by the time someone posted the answer.
B: You're running 15psi? What kind of fuel modifications do you have to support that?
