Dr Funkenstein
- 322
- 2
- Aug 5, 2010
Bangfield,
Massachusetts
Hello everyone,
Some of you may remember me, but in all fairness most of you probably don't. Over the summer I purchased a 1991 Eclipse GST with 166,XXX miles on the clock for $1,000. It needed a few things fixed on it, but what 20+ year old car doesn't?
Little did I know, that every time I fixed one thing, two more things would break on it. So far I have replaced the hatch struts, alternator (VR4 version), power-steering pump, driver's side mirror, battery, calipers and pads (EBC Green Stuff; rotors were brand new), radiator and a bunch of hoses. I installed my Alpine head unit, NGK spark plugs and wires and a K&N air filter.
Seems like a good start, right? Wrong. As it sits now, it needs a new head gasket. I was undecided between selling the car and keeping it. In the end, I realized I wouldn't get back even half the money I invested into it, so I decided to keep it. Funds are low at the moment because I got laid off. However, I should be going back to work soon and thusly am ready for phase two of my project.
I plan on this being my daily driver. Some may call be crazy and some may call me a moron. Both accusations may be correct. However, this is my goal. I will be stacking away money once I start working again so I can drive my baby. While I am getting the head gasket replaced, I figured I may replace a few other things. The plan so far is as follows:
1. Head gasket. (OEM or MLS?)
2. Timing belt. (OEM or aftermarket? i.e. GReddy)
3. Water pump.
4. Valve stem seals.
5. Lifters (Re-visioned or 3G?)
6. Balance shaft eliminator kit (Mitsubishi or RRE?)
7. ARP head studs
I'd appreciate your opinions on the above. Also, let me know if I am missing anything I should look into. I had spoke to my father's mechanic a couple months ago and he quoted me at around $1,300 for the HG, TB and WP, so I hope to keep this under $2,000. I should also mention that I am still leaking power-steering fluid from somewhere above the exhaust. I also need new tires and to take care of the rust.
What did I get myself into?
Sorry for the long post, so here are some pictures of my baby.
3. Water pump.
7. ARP head studs
