19904G63turbo
- Jan 27, 2012
Chester,
Connecticut
as of right now i have a block that is built using wiseco 8.3:1 pistons. its bored .40 over. i have been looking to get CP pistons that up the compression to 9.0:1 with the same bore size. I was wondering if i would need to get a different block to do this on or if i could still use the same one i got. The block i have now is bored to meet the specs for the wiseco pistons
i hope that this will help definitley check manufacturer specs before doing this piston swap because you could dump a ton of money on a mod that will not have noticeable benefits
