need a crank
bigpoppa694lyfe
Apr 30, 2009
lewistown, Pennsylvania
ok so i need help finding a crank. im not sure if its a 6 or 7 bolt yet but id appreciate if any1 could help me find 1. im in the lewistown area and we have nuttin. ill check in later when i know which bolt pattern it is. until then jus please try 2 get me prices. thank u
I have a stock 7-bolt from an engine without any issues. Still needing one?
I have a stock 6 bolt crank that is in reall good shape if you want to check that out..
who is this by the way.. the engine should odviosly be a 7 bolt unless it was swapped.. is the motor out of the car
