bosljeff
Okay here's the rundown. I dropped $1K with wheelmax on a tire/wheel package. Love it. They swore it would not rub it does (235/45/17 17x7 45mm offset). You'll notice the offset is very bad, should be 35mm, well until I can get them to exchange, I need some ideas for options.
Front tires rub a little on the flimsy wheelwell engine bay plastic-not too worried I can trim, but the big concern is where the corner of the tire is rubbing on the "cone" of the strut. See red circle on pic.
Now, do aftermarket shocks/struts/springs have less "girth" to pull that "cone" away from the tire?
I don't want to do spacers:
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=85399
So I need some options until wheelmax miraculously comes through. T
Thank you for any and all ideas.
