Installed Ground Controls, Car is higher now
bigfoot
389
Aug 30, 2002
LOL. They sent me 9" rear springs and 8" fronts for my GVR4. I've got the rings all the way down and the front is 1/2" higher than stock, the rear dropped only 1". I figure I need 2" shorter springs in front for the drop I wanted plus some room for adjustment, or 1" less and cut off some of the perch on the AGX's. I got 375lb. front and 350lb. rears with AGX's and a ST rear sway bar. This is a high HP 95% street car, but I'd like to run it on open track days on the PIR road course. I want a controlled BMW type ride, not too stiff. I'm going to drive it tomorrow and check out the ride before I send these springs back, but I'd like to hear some opions too.
What spring rates and lengths do others run? Did you cut the AGX perch?
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
