xEclipsERaceRx
- Feb 16, 2003
I went to a shop yesterday and got a front end alignment, and on the way home I noticed my car was sliding all over at highspeeds on the interstate. Like i had bald rear tires driving in the rain. So I go back and try and get a rear end alignment, they couldnt move the toe bolt. It was seized on there. So I goto another shop and they adjust it, but it wont adjust enough. And my toe is still way out of whack He told me to research and try and find a toe adjuster bracket or something...what do you think? My rear left tire is slightly off...and the rear right side is way off way way off.
Left Rear Tire
Toe: 0.02 (specified 0.00 - 0.24)
Right Rear Tire
Toe: -1.03 (Specified 0.00 - 0.24)
My right is rear off, so do you think its only a bent control arm? A lady dide side swipe me in the side like 2 years ago in the right rear (where they are having all the probs. its did leave a big golf ball size gash above the rim in the 1/4 panel. Do you think it could be that? So do you think I only have to goto a junk yard and get a used control arm? Could it be anything else?
I do have a camber kit if that matters in the rear.
Left Rear Tire
Right Rear Tire
it was going through tires every 2000 miles. I bought the upper control arms (From Mitsu the control arms are like $60 each), then brought it to STS. They said they didnt need to change them, bu thtey put a camber kit in. This allowed them to make the drastic adjustment to fix the alignment. Or your car might have to be pulled. The shop will have to attach the thing to the strut tower and pull it back into shape. Obviously, mine needed both
