Brake upgrade on a budget
Race94
1,151
Jan 6, 2003
Puerto Rico
Hi guys,
i would like to upgrade my brake system but i'm on a budget. I was thinking of getting slotted and drilled rotors and new brake pads.
Any suggestions on brands? models?
Anything else i should also upgrade?
90-92 with ABS front $95.00 per pair
90-92 non ABS front $90.00 per pair
90-93 rear all $90.00 per pair
93-99 FWD non Turbo $90.00 per pair
93-99 AWD front $100.00 per par
94 rear vented AWD $110.00 per pair
95-99 rear all model $80.00 per pair
Front pads, $40.00, rear pads $35.00
90-94 ss lines are $125.00 full set, 95-99 ss lines are $85.00 full set.
We offer dimple/slotted, cross drilled/slotted, slotted only or cross drilled only.
http://raceconcepts.net/car.php Email Wood, and tell him Matt from DSMtuners sent ya:thumb:
Before you spend any money on stock sized rotors check your local junk yards to see what they want for the dual piston calipers off the AWD's. I paid $35 each for mine and it was worth every penny. Since the difference in caliper cost is $10 so for $90 more than just fixing your brakes you can have much better ones.
Steve
what other car calipers and brake parts will fit my 95 GST?
Many Mitsubishi cars use the same calipers/mounts. The Big Brake VFAQ lists some of them. What you want to keep in mind is your car uses a banjo fitting to attach the brake line to the caliper. If you asking a yard for calipers and brackets just ask for fronts off a '96 or later GSX to be sure. Their inventory is usually cross referenced by usage so they can sell a part that's the same between cars regardless of which model and year it came from. If your kicking around looking to pull some try '94+ Diamante's, 3000GT base and SL models. Just check to make sure their banjo style fittings or you'll need custom brake lines.
Steve
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
