Energy Suspension
tsunari
1,030
34
Feb 12, 2003
Jessup, Maryland
Ok, recently found out that the camber on these lovely cars is adjusted
by bushings (set to different angles). If I'm not mistaken, it would be the upper control arm bushings. So my question is- installing the Energy Suspension bushings, woulnd't I need a camber kit? I installed the front set this past weekend and when I *attempted* to adjust the upper control arm to factory specs, I found out that the new ES bushings weren't designed to hold those settings.
Has anyone who's installed their ES bushings run into this?
EDIT : Has anyone found a solution?? :(
Just to update/close this thread- I ended up getting an Ingalls camber kit. Everything's golden now . . .
