Need Help put on prokits and somethings is fu@cked up
daltah
516
Sep 27, 2002
phoenix, Arizona
I put the eibach prokits on the back of my car today and soon as i was done pulled out of the driveway and went down the street and i hear a clunking noise in the back coming from the struts so i go back home and took off the plastic cover and rubber cap on top of the struts and the struts were shot up.I took it apart on one side and the struts arent blown and everything was put back together the same way and it still did it again.Does anyone know why its doing this and how i can fix it?I put my coilovers on before and never had this problem.
no its not i could see the struts that shot up when i took the plastic covers in the trunk.
No they still work if i push them down they come back up.
1. did you install new shox with the springs?
2. if not they could be blown, they will eventually.
3. if you saying that the rod in the shocks pushed up through the upper shock mount, then you forgot to put your dust covers back on. they are the metal cap attacked to your old dust boots. without these their is nothing to stop the shock from pushing up through it.
4. if 3 is the case install the dust covers and your all good.
