1G lowering
Redlin'r
78
Jun 11, 2003
I have been considering lowering my car for some time. I have looked into it, and decided Eibach Sportline and KYB gr-2 shocks/ struts are fesiable. I am not looking for a really aggressive drop, more for performance and ride really. Do you guys know anything about either of these products or have experience with them??? Let me know..
Roger......
I am hoping they are good, I have done research and they seem to be a good quality drop and provide responsive/ stiff handling.
Originally posted by lenz
ok so i just bought some coil overs, how much can you lower a 1g with out it rubbing. i have 16 in rims but i don't know the tire size.
With coil overs you can just guess and check. Watch out for Camber adjustments though. Did you get sleeves or a coil over kit?
how many miles are on your car? I only have about 99,000 on mine but am replacing the entire thing. I will help stiffen everything up too, so it might not be as bouncy.
Wow, You will definetly want to replace the stock suspension then as well. If you don't, it may last a few months, but they would definetly blow out from the lowering, escpecially if you are dropping it that low. And when it comes to shocks/struts don't go cheap. Get a good set and it will make the difference, if you got KYB AGX adjustables and your R1 wouldn't be a bad set-up...
they will most likely blow with that much stress on them and being so old.
