Worn Tie Rod ends
TSi999
443
Apr 25, 2003
Stoned Mountain, Georgia
I was checking my DSM CD and didnt see too much refrence to it and ive done a search.
Curious about who has changed their own tie rod ends is this a project that can be accomplished in the garage fairly simply?
I know the parts are pretty cheap but labor rate seems to be fairly expensive from what ive seen.
Thanks/
it's really simple dude. mines were stripped so i had to replace them. 19$ at shucks. all you have to do is unscrew the nut holding it down, then use a tie rod puller to break it loose from the post it is sitting on. and then just unscrew the tie rod off the power steering rack. you'll need an adjustable wrench and another size wrench to break it loose. it is on pretty tight. good luck.
Thanks buddy...
thats a beautiful car by the way !
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
