| Handling Tech Suspension, steering, brakes, tires, lightweight wheels, bushings, etc. |
03-28-2003, 04:18 PM
#1 (permalink)
Proven Member
Bump Stop [Merged 7-7] stops
i'm goin to install my springs n shocks soon...and i was wonderin why or if you even have to cut the bump stop. any info is apprecitated.
Offline
03-29-2003, 08:24 AM
#2 (permalink)
Proven Member
b/c your losing an inch or 2 of shock travel by lowering it (depending on the springs you get) they recommend cutting 1/2 to 3/4 inch to get some of the lost shock travel back.
Offline
03-29-2003, 08:52 AM
#3 (permalink)
Moderator
Quote:
This is very true, NOT all springs require you to cut the bump stops. For example my neuspeed sport spring, I had to re-install a new bump stop in there because i cut off too much and the car would kiss the tire sometimes. I then found out that neuspeed says not to trim the back bumpstop when using their product.
____________________________
Ed
Offline
03-29-2003, 10:45 AM
#4 (permalink)
Proven Member
i have eibach sportlines 1.75 or 1.8 drop on these. and i'll be runnin on some AGX's. You guys think i'd have to cut the bump stop?
Offline
03-29-2003, 03:39 PM
#5 (permalink)
Moderator
Like was said above... it depends on what the manufacturer states....
Ed
Offline
04-01-2003, 12:40 PM
#6 (permalink)
Proven Member
ProStreetOnline
If you don't trim the bumpstop, you will end upo banging your upper perch onto your shock body, destroying the shock.
You only need to trim the bumpstop if your car is constantly sitting on them. Sitting on the bumpstop only hurts suspension performance, increases cabin noise, and makes the car unsafe.
Offline
04-03-2003, 03:17 PM
#7 (permalink)
Proven Member
With sportlines i think you are supposed to cut the bump stop 1/2 way. I had to cut mine 1/3 or so with the pro-kit. My springs came with a sheet that shows how much to cut it.
Offline
04-07-2003, 10:55 AM
#8 (permalink)
Proven Member
Car: 2005 Audi A4 1.8t quattro USP
Region: Mid Atlantic
you mind sharing that sheet with me? my car is in the process of having tokico blues and eibach pro kits installed on it.
-AJ
Offline
04-07-2003, 11:07 AM
#9 (permalink)
Proven Member
Region: Southwest
Should you cut the fat end or the thin end?Also i have coilovers on my car and have them all the way up but it still sits between 1-1 1/2 inches lower than stock so how much should i cut off?
Offline
05-31-2003, 10:12 AM
#10 (permalink)
Proven Member
Bump Stop
Hi, my front supension bump stops are all teared up and less than quarter inch is left on the shocks(my car is lowered), i called satan and they have to order them i dont have time to wait. I also checked scrapyard and the bump stops there are all the same condition as mine  .No auto parts cary them to,My question is can i make them, im thinking of buying maybe some rubber or prothane bushing drilling the middle hole bigger and using them as bumps stops. Is this a good idea or this will mess up my suspension because they are harder (rubber/prothane)than foam stock bump stops. what do u guy's think or u have better i deas of making the bump stops. Im open to any suggestions.thank you.
Offline
05-31-2003, 01:56 PM
#11 (permalink)
Proven Member
I would say just get OEM..You can TRY your way BUT it may be harsh if you bottom out since OEM ones are more "mushier".
-Kunal
Offline
06-10-2003, 06:44 AM
#12 (permalink)
Proven Member
Where to Cut Bump Stop
Does anyone have a picture or know where I can get a picture that will show me where to cut the bump stop? I just got the Tokico Illumina shocks and spings 1.75 drop. Thanks.
Offline
06-10-2003, 09:59 PM
#13 (permalink)
Proven Member
Car: '06 Evolution IX SE
Region: NorCal
Here are some pics. This is what I went by.
http://www.vfaq.com/mods/GCkit-2G.html
You'll find some pics of cut bumpstops in there.
Offline
06-11-2003, 06:05 AM
#14 (permalink)
Moderator
Re: Where to Cut Bump Stop
Quote:
It all depends on what the manufacturer of the SPRINGS tells you. I made the mistake of cutting mine and come to find out with my springs there is no need, or rather the manufacturer suggests not to trim them.
All I am saying is make sure you need to cut them before you do.
Ed
Offline
06-11-2003, 07:05 AM
#15 (permalink)
Proven Member
Thanks for the help. I got the Illumina shocks and springs yesterday. I did not think that there would be any instructions but there were. They recommend cutting them in half. They even included a diagram. I just wanted to be sure before I installed them. Thanks again.
Offline
06-30-2003, 07:48 PM
#16 (permalink)
Proven Member
cutting bump stops
okay i have a 91 gsx i have rage 5.0 wheels and nitto tires. i just put aem brake converstion and a rnr 2.5 turbo back exhaust. i am putting the suspension together. i think i am getting 4 gr2 shocks and ebiach springs. this will lower my car about a inch all around. do i need to cut the bump stops to compensate. please guys tell what you think. i am not building a race care just something that is really fun to drive.
Offline
07-02-2003, 09:44 AM
#17 (permalink)
Moderator
When you get the springs, there will be a note from the manufacture in there telling you how much to cut if any. It all depends on the spring. No two are alike.
Ed
Offline
07-02-2003, 10:18 AM
#18 (permalink)
Proven Member
What if you leave them out?
Offline
07-02-2003, 10:33 AM
#19 (permalink)
Moderator
Quote:
Then you could damage the shock if the spring compresses too much.
Ed
Offline
07-02-2003, 11:10 AM
#20 (permalink)
Proven Member
thanks for the help when i first got my car the guy i bought it from said he just put shocks in the front and then he handed me a box of parts the bump stops were in there. i didn't put them back in and about 3 months later the shocks were history.
Offline
05-23-2004, 02:31 PM
#21 (permalink)
Proven Member
Eibach sportline bump stop question
Does anyone know how much I trim off of the front bump stops, I've lost my directions for my springs. They are for a 1991 AWD. Need help. Thanks.
Offline
05-23-2004, 11:33 PM
#22 (permalink)
Proven Member
Not to jack the thread, but I'd also be interested in knowing this, if anyone has the info for Pro Kit springs as well, that'd be wonderful.
-Cliff
ex-93 TSi AWD, 92 1.8L.
Offline
05-24-2004, 07:55 AM
#23 (permalink)
Proven Member
new shocks, 1.25 inch drop. Cut bump stops?
I'm sure this has been asked before but my 98 gst is lowered 1.25 inches with tnaumi springs or however there spelled. I just got my kyb adjustibles today so when im installin my new shocks id figure id cut the bump stops. How much do i cut? why do i cut? do i need to cut with only a 1.25 inch drop i cant seem to find a sure fire answer on this one. Any wiseman help would be appreciated
powered by 14b turbo
Offline
