Romeyo07
- Jan 27, 2005
Fort Myers,
Florida
I had to re-run hard lines that were cut and removed from the car to the rear brakes. I purchased 3/16" brake line tubing and ran it each way. Connected to existing hard lines with no problems.
I purchased new hoses for the drivers side. That side went in with no problem. I wasn't originally going to replace the hoses on the passenger side, but decided to since, well, it made sense to have new ones back there. Ends up that the hose I purchased doesn't have a 3/16 female end like the other side, yet it fits perfectly on the caliper.
What do you think I should do? Would using a larger steel nut for the hard line work (and seal)? Should I get an adapter to fit?
