Initial DSM
- 903
- 1
- Jan 30, 2003
97 Eclipse gsx,
New York
Has anyone heard of Stempf Extreme range adjustable ball joint kit for front and rear? I recently got a new suspension (Tein Flex), and the alignment guy says its the best kit to correctly fix my camber and caster problem. The only problem is its price (600). He says camber/bushing kits wont totally fix the problem, because they dont have enough range to fix it to spec. The car was aligned; but all that did was correct the toe. Who knows the exact specified ranges for 2g eclipses? Here is what he said:
Left Front Right Front
Actual \ Specified Range Actual \ Specified Range
-1.4' -0.6' 0.4' Camber -1.8' -0.6' 0.4'
0.4' 3.2' 6.2' Caster 5.5' 3.2' 6.2'
0.00' -0.12' 0.12' Toe 0.00' -0.12' 0.12'
Left Rear Right Rear
-2.5' -1.8' -0.8' Camber -2.6' -1.8' -0.8'
0.10' 0.00' 0.24' Toe 0.10' 0.00' 0.24'
The 'Actual' is what my car is at now. The 'Specified Range' is what the OEM specs are, or at least what would be the least resistance to tire wear. Just wondering if this looks familiar to anyone. So basically, this stainless steel ball joint kit gives more adjustability than the bushing/camber kits sold online, which should fix the problem he says. Has anyone heard of suck a kit? He says you cant order it direct. The possible reason my left caster is so bad could be of a recent broen control arm that I replaced. I tire blew out on a manhole. Is this kit worth it? Am I wasting my money on a camber kit that will not fix the problem? He's done the ball joint kit for mainly Hondas in the past.
I need a 2nd or 3rd opinion.
I see what youre saying about the right being more than the left, but still at 0.4 on the left, thats pretty bad; way off from 3.2. I gotta call that guy and see where he got those specified range specs. Any online links to service manuals?
