markmakeitso
- 366
- 2
- Aug 21, 2002
Good day eh.
I was throwing new rotors and pads on the rear of my 91 AWD the other day, and I couldn't swing the caliper back over the new pads, turns out the piston was hitting a little bump on the back of the pad backing. If I turned the piston out a bit the bump would fit into the slots on the piston face, but then it seemed like the piston couldn't turn any more once the pads started to wear. Finally I ended up pounding the bumps flush with the shim so they could close right.
I double checked the parts number at Napa and asked them about it, but they had no idea what I was talking about. Anybody else had this problem before?
