camber kits with sportslines
get either specialty products or ingalls camber kits. make sure you get the ones with up to 3 deg of correction all around
yes very true. you are going to hate camber and toe if you don't get the camber kits. also, please get your car alligned. if not, the camber kit is not going to do much good. so please get it alligned.
later
Eibach front camber kit is about $32. The Ingals rear camber kit is $199. The best prices I've found are here: http://dsmparts.com/ , they are supposed to be getting the next shipment of Ingals this or next week.
So how much do you think I'm looking at spending if it's like 2-3 degree's all around.
i had 3 degrees in the rear and did the $15 camber mod but added a couple extra washers to move it out some more. after the allignment, my front and rear was in factory specs but only the rear needed camber kits.
later
where do you guys go for an aligment ??? pepboys? and how much is it? i got front camber kit and i can install , then go an do aligment. installed rear one which was piece of cake...
thx
most places will not allign lower cars for two reasons:
1. we cannot get on their allignment machine b/c we are low
2. since we are lowered, and we are using camber kits to adjust our camber/toe, they cannot gaurentee their allignment for life or so many miles or whatever their gaurentee is.
usually shops that deal with lowered cars will do it. if not, just ask around.
later
