1G 90 fwd use 3000gt NA brakes?
z24frank
370
Nov 26, 2007
san diego, California
Ok my room mate just crashed his 98 3000 gt n/t base .I have searched to see If I can use his brakes on my car but the only thing that comes up is awd cars! I have a 1990 FWD.So my question is can I use his brakes?I can basically take the rotors and calipers off and lines too if they will wok?
No they are the 2 piston non turbo calipers,Do I use his rotors also? and what brake lines do I use?
Yea its a direct bolt on, I just did the same swap on my 90 Laser. My rear calipers were sticking so I decided to upgrade the the front while I was at it. I bought 98 3000gt n/t calipers off ebay and just bought pads and rotors for the 3000gt and everything fit perfectly. Wish I would have seen this thread before I did mine I would have jumped all over those OEM rotors over the Napa units I got.
I have these on my car. Im regreting it these days. Ill be talking them off this winter so i can run a nice 15" wheel for some good slicks. =D So, if you plan on taking your car to the track or just taking some weight off there is not a need to upgrade your brakes.
Now is this the same for fwd 2g's also? Everything bolts up?
Yea it is, only some of the 95 AWDs have a different hose. I had to replace all my brakes anyway they were getting crusty and the LR caliper was sticking, overall im happy with the improvement in braking and it was easy and cheap to do. My only regret is not getting the OEM rotors, the Napa ones are already starting to rust.
DSM Big Brakes INFO
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
