Need to find part numbers for bolts
bpestilence
271
2
Jul 26, 2004
Pearl City, Hawaii
Perhaps someone can help. I have searched JNZ's site and this site, and I have not been able to locate the bolts that I am missing.
They are the lower control arm mounting bolts. The two bolts that connect the front lower control arm (the angled one) to the subframe.
I think the kids next door misplaced them. In any case I cannot find these bolts locally... They are a strange thread, maybe 14mmx1.5 or something like that.
not exactly sure which one you need so hopefully this helps
That's the problem. The picture does not actually show any of the bolts used to MOUNT the control arms.
In this picture it is labled "pivot arm".
Thanks to PsimyTSi for finding the part numbers!
MF101314 80mm bolt
MF101320 65mm bolt
MS450044 lock washer
They were dirt cheap on JNZtuning. $11 for hardware on both sides. (I replaced both sides because the ones that I still had were badly corroded)
Now my car is FINALLY back on its wheels. Interesting note... The tie rod ends I got from Mitsubishi were definately longer than the stock ones. I ended up 5 degrees toed in on both sides after replacing them. Got it straightened up by eye... The car will need an alignment anyway. Another interesting and sort of crappy note. My brand new ball joint boots are starting to crack ALREADY. WTF? I have had them on the car a month and haven't even hit the road yet.
