proper spring heating technique?
pj2nr
Dec 18, 2002
if anyone has heated their springs for lowering,let me know how ya did it.heat'em while their on or take'em off? any help would be sweet
dude i dont recomend doing this but its your choice.....from what i know u leave them on so the weight of the car will push down on them to lower the car. after u get the spring where u want it u spray it with water to get it to set. i dont know the full process but i hope this helps u
thanx for the help,ive had a car with heated ones before,i just didnt know how it was done,yeah it did ride like a broke-back mule,but i roll ghetto:cool: .naw ill probably just buy some. appreciate the help though
nope just curious how people did it, but thank you anyway for youre criticism:thumb:
I always thought people just cut a couple of the springs off (still not a good idea since it raises the spring rate) since heating the springs changes the metal properties, ie, fatiguing the heated portion.:(
DO NOT HEAT THE SPRINGS!
If you want a ghetto lowering job cut them. But you MUST keep the spring cool (cold) Run water over it constantly while you cut. Listen to ImportModder.
Spend the money and ensure that you don't go flying off the road or into someone when your spring snaps from cutting it.
