tokico 1.75 too much?
kiakarimi
189
Jan 7, 2003
I was thinking about getting the tokico Hp handling package that has Shock/Spring Combo (HP Non Adjustable) AWD 1.75`` Drop. I was going to do this on my stock rims, and i was wondering if this is maybe too low for daily driving use? Does anyone have the same setup? Any input would be appreciated. Thanks!
1.75" isnt much at all. If your doing this drop on stock rims, you will be more than fine. In fact, you can most likely sqeeze 18's on a drop like that. Either way, itll be fine.
I have it that kit on my car and it looks like a good ride height. It is fine with the 1.75" drop; the drop for the GSX is a bit more because it sits .25" higher than the GST. The only time you might encounter problems is if you put a lip on like I have on my car. I know it's going to get destroyed but it looks nice.
front
side
I have 17 x 8 Konig Tantrums on my car.
1.75 isn't all that much. My car is drop approximatley 2.0 with the bodykit on if you remebered what my car looked like at the little South Center meeting.
