4-Piston Brakes.... what rims fit?
tqlla
165
Nov 23, 2002
Hey, I want to get 4 piston brakes. Since my skills are low, I like to make it up with Big Brakes. Well, the question is, what Rims will fit a 99 GSX, and 4-piston brakes.
I know its pretty hard to find brakes that fit a 3000GT VR-4, and they use 8.5 inch rims. Will 8.5 inch rims fit GSX... if so, I will just get 1994 17X8.5 3000GT VR-4 Rims
http://www.machv.com/baerracprobr.html
Did you read the add?
"Does your car see more road race miles than highway miles? You may need the Pro Brake Upgrade from Baer. The kit uses the same rotors as the Track setup above, but moves up to a race-bred Alcon four-piston caliper. For the ultimate in Eclipse braking, step all the way up to a 13.5” two-piece 48-vane rotor. They’re not cheap, but you knew that, right? Pro brake kits require 17” wheels"
Look at the last sentence:rolleyes:
Yeah, I read the Ad, I guess you didnt read my post very well. Notice the empahsis on wheel width. And not wheel diameter.
I can telljust by looking at the wheels, that the 17X6.5s on my eclipse are not going to fit over my 3000GTs 4 piston brakes.
Thanks Tevenor, Those brakes on the TCE website are pretty impressive, esp for the price.
