Wobble
- 726
- Jan 2, 2003
ok.,. my car hops like crazy when i launch.. so far iver tried:
prothane motor/tranny mounts
lowering air pressure in front tires
raising air pressure in front tires..
AFAIK my launchers with 20PSI are about the same as with 30 PSI.. same amount of hop.. same traction (kumho estca supra 712s) so i just run 30 psi because its seems to handle better that way..
what can I do?
will stiffer REAR shocks help this? if so where can I get a set for a LOW price.. I.E. not $150 per shock!
i imagin the front ones are ok, just the back ones need to be stiffer..
ideas?
what can I do?
ideas?
