Rotor Bracket Bolts
yellowkyd278
124
Sep 28, 2004
Los Angeles, California
I'm about to install my Wilwood big brake kit but realized I'm missing the 4 bolts for the conversion brackets (2 on each side). The specs for the bolts are 7/16-20 x 1.25 Long. Are they a special grade and do I have to order them from Wilwood/TCE or can I just get them from somewhere like NAPA or Orchard Supply.
I'm currently running th stock 2g AWD brakes.
Wilwood kits come with grade 8 bolts. Make sure you buy proper fasteners... If the bracket broke off, not only would you not be able to stop, but your suspension would pretty much be toast.
Yes, you can get grade 8 bolts from most places. Napa will sell them. Just ask the counter dude.
Anywhere else I could give a shot?
If you're in LA, check the substantial Yellow Pages for any number of industrial fastener counters. They'll not only have 8's in your size and pitch, they may even have choices, such as integral serrated washer, etc.
