JLangevin
- 155
- 1
- Oct 14, 2005
Rialto,
California
Im sorry, but this may be a long post, please bare with me, and read all of it... you may have the answer I need.
Vehicle:
1995 GST Eclipse, Automatic
Ok, so on 11/11/06 I had my right front axle replaced due to an extreme failure. The axle actually came out in pieces, lucky for me, it did not damage my tranny. (This was not due to racing, I do not race my car on street or strip anymore)
The symptoms at the time were a BAD vibration, thunking when turning, accellerating, or decellerating.... when just cruising at a constant speed, it didnt do much noise or vibrations... It reminded me of having a large rock or something stuck in a tread, but very severe.
So the axle was replaced, and Im on my merry way.... Until today (7/31/07) - Im driving to Pasadena, CA for work and the car is driving along fine. Traffic begins to slow, and so do I... as traffic begins to move, i give it some gas, and WHOA..... Steering wheel being pulled to the right heavilly, then center, then right, then center... like the pullsating you get from warped rotors, but on the right side... but only when accellerating. Im thinking... WTF... Wheel bearing? But then it stops...... So I finish my business in Pasadena, and head back to Redlands, CA (about 60mi)... Im driving along, everything is fine, and when I get off the freeway again, I pulls to the right, but now the pullsating and pulling of the wheel is to the LEFT and only when DECELLERATING, not accellerating like before.
There is a slight "shallow" metallic clinking that sounds in sink with the rolling of the wheels every so often.. speeds up with wheels, slow down with wheels, not RPMs... So I KNOW its suspension/steering related. There is no wierd play in the steering where, and have not been able to jack up the car yet to check for wheel play. The axle is under 100% labor/parts warranty until 11/11/07, so Im covered there, but Im not so sure its the axle..
Before these guys look at it and say, "Its not the axle, but its the tie rod ends or hub, or yadda yadda...." Id like to get your opinions on it.
So, basic symptoms.
- Slight clinking of metal from time to time, in snyc with wheel rotation speed, not hard thunk like the axle went out prior.
-Car pulled to right and steering wheel wobbled left and right. If I Lock the wheel in place with my hands and knees, the car itself does not pull right and left, just the wheel.
-Car switched from pulling slighting right, to slightly left after a few min
-Car went from wobbling the steering wheel on accelleration, to decelleration with no change in driving pattern.
Any experts willing to throw out a thought?
Vehicle:
So, basic symptoms.
