boostedinaz
DSM Wiseman
- 3,835
- 16
- Dec 22, 2002
Scottsdale,
Arizona
So I had my car aligned a few months back and it was fine for awhile. After bit the left front tire would move slightly as if I had added some positive camber and the steering wheel would be off center (like I was turning right). When that started it also started to wear the outer edge of the tire as well. This does not happen all the time. Sometimes the wheel and tire are at there normal settings and the steering wheel is noce and straight. Then other times it does this weird thing. I pulled the wheel off and I could feel the lower control arm move a bit if I pushed it back and forth. This weekend I installed new poly bushing and ball joints in the control arm and hoped that fixed it. No dice.
What I am wondering is what would cause this to happen to only the passenger side wheel and tire. I don't mind replacing things but I don't want to just start throwing parts, and money, at it if they end up not working. The only thing I can think of would be the rack or possibly the out tierod ends but I looked at those and they seemed fine but I am not a suspension expert by any means.
Any help is appreciated.
