Side to Side wheel movement
Posted by spyder97gs, Jul 28, 2005
Handling Tech - 4G63 suspension, steering, brakes, tires, lightweight wheels, bushings, etc.
Please Support Jackson Auto Machine
  1. spyder97gs
    spyder97gs Proven Member
    Dec 10, 2004
    528
    5
    Greencastle, Indiana
    My passenger side wheel wiggles side to side with about an inch of freeplay on both sides. What is this an indicator of? Tie-rods or balljoints? My axle needs replaced I know that already. My wheel squeaks, creecks, and everything else when driving. Thanks.
    #1
  2. Spidey
    Spidey Proven Member
    DSM Profiles:
    Sep 22, 2002
    881
    7
    Charlotte, North_Carolina
    Sounds like you need a wheel bearing, how many miles are on the car?
    #2
  3. GritsnGravy
    GritsnGravy Proven Member
    Oct 28, 2004
    36
    Brownsburg, Indiana
    I would bet it is the wheel bearing. Replace it and you should fix your problem.
    #3
  4. RamenPride
    RamenPride Proven Member
    DSM Profiles:
    Aug 18, 2002
    2,279
    51
    Virginia Beach, Virginia
    I concur
    #4
  5. wret
    wret Proven Member
    Jul 3, 2003
    2,695
    51
    Bel Air, Maryland
    Does it move top and bottom or just side to side?
    #5
  6. ImportModder
    ImportModder Proven Member
    DSM Profiles:
    May 30, 2002
    230
    Washington, Wisconsin, Michigan
    Side to side indicated tie rods. Top to bottom AND side to side indicates wheel bearings. Bad wheel bearings make a roaring sound while driving. Hard to miss.
    #6
  7. spyder97gs
    Dec 10, 2004
    528
    5
    ONLY side to side. Now top and bottom movement. I put the front end back together, and when I originally took the tie-rod from the knuckle, I noticed the inner tie-rod just dropped straight down and had no stiffness to it. Last tie-rod I put on a car was rigid and not completely loose. Wheel bearings have been replaced recently. Did a motor swap and 5spd swap, trying to work all the bugs out now. Damn passenger side wheel is squeaking like crazy. It doesn't roar though.
    #7
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
