2G rear drum to disk conversion
paceman
Sep 22, 2002
What would I have to do or buy to get 13in rotors and 4 piston capilers were my stock drums are or could I get an awd set up and upgrade i need help
having 13" rotors in the back is overkill man. I did the rear disk conversion on my RS and just upgraded the rotors to some stock sized slotted and cross drilled rotors. Just go to a salvage yard and get the rear control arms, hub, rotors, brake lines, emergency brake cable and calipers to make the swap as easy as possible.
