2G 45mm or 35mm offset for AEM big brake kit front and rear
stealtheclipse
May 21, 2005
CHALMETTE, Louisiana
Hi i have a 96 eagle talon awd and im putting 19x8 inch exel 012 012_z.jpg and i want to put an AEM big brake kit front and rear and i was woundering if i should go with 35mm or 45mm??? :dsm:
Do you have the rotor kit utilizing OEM calipers or the 4-piston caliper kit?
In that case there is no easy answer and not too many practical options for test fitting. Unless you select a wheel that is recommended for a vehicle that uses stationary calipers you will probably need spacers. It's not really the offset of the wheel that affects the fit, it's the shape of the spokes.
If you are really committed to those wheels and you are willing to use spacers, you should probably go with -45mm offset. That way when you space them out, they will be in the right offset range.
well what if i used the stock calipers??
95-99 Awd O.E. system Front
AEM big rotor brake systems AEM big rotor brake systems relocate the factory caliper via patented caliper relocation brackets that change the moment arm for increased brake torque, which helps reduce stopping distance by an average of 33 percent.
95-99 Awd O.E. system Rear
You should be able to fit just about any wheel over the AEM brakes with OEM calipers.
Are you asking which will fit better, which will work better, or which will look better? The answer to any of these questions depends on your goals. What you want to spend versus what you want to achieve.
