suspension for a spyder
96'GSspyder
204
Aug 14, 2002
alright, just some questions about suspension for a spyder. since my car is a spyder, it doesn't handle bumps and stuff like a normal hard top car cause its missing the extra support that a hard top car provides. in the interest of tightening up the body, i looked into buying RM racing sway bars, front tie car and a rear lower tie bar, since i don't think the top would go down if i had an upper rear tie bar. i also have koni shocks with ground control coil overs. is there ANYTHING else that i can use to tighten up the car and make it handle better? i was thinking about a floor cross bar, but apart from that, I'm not aware of anything else that will help me. does anyone know of anything else that will help me, apart from sway bars, sturt tie bars, and cross floor bars?
You can fab up some supports that go across the bottom of the car. Kinda like a floor bar, only on the bottom of the car.
true, but do you think the car would be tight enough with sway bars, ties,and a floor bar? or do you think its worth it to go the extra mile and put cross beams to keep the frame straight?
