CrazyUglyCoyote
- 143
- Feb 7, 2005
Tucson,
Arizona
Im looking for a set of Coil Over suspension w/ remote oil resivoirs. I need them for a 1991 AWD. Any sugestions? Thanks!
__________________
__________________
Tein makes the only unit I know about, there are more than likely others I am not aware of though........CrazyUglyCoyote said:Im looking for a set of Coil Over suspension w/ remote oil resivoirs. I need them for a 1991 AWD. Any sugestions? Thanks!
__________________
__________________
khanlon said:Why are you limiting yourself remote reservoir shocks? It is my understanding that they are only necc. for rally and possibly track use. This is because the remote reservoirs benefit from increased oil volume, hence reduced shock fade from heat.
I would think if you are autocrossing, drag racing, or street driving a requirement for remote reservoirs would be overkill.
CrazyUglyCoyote said:Exactly. Im trying to build a full track car. I have experience w/ remoter resivoirs from when I used to race quads in the desert. And aside from being so freakin easy to adjust w/ just the turn of a knob, I need somthing that I can have re-built when needed.
Hmm, you obviously never had an experience with the double or especially the triple adjustable shocks! Otherwise you would not make such a comment!khanlon said:Why are you limiting yourself remote reservoir shocks? It is my understanding that they are only necc. for rally and possibly track use. This is because the remote reservoirs benefit from increased oil volume, hence reduced shock fade from heat.
drivemusicnow said:(sorry slightly off topic) whats the third adjustment in a "triple adjustable shock" i know about rebound, and compression, but can't think of the third adjustment.. and how expensive are these?
definitiveno said:I guess ground control offers a new line of dual adjustable shocks that they claim to be THE BEST bang for buck, 400 a corner. They look really nice.....
http://www.advance-design.com/
