AGX Settings: Best set up for 1/4 Mile
GSXlaunch
392
Sep 3, 2003
Just wondering what you guys with AGX adjustables have them set to (both fronts and rears) for the best possible launches. I am installing mine on my 90 GSX this weekend...thanks.
TT
TT
softest up front (1) and stiffest in the rear (8).
These settings have worked the best for me.
Thanks fellas...guess I'll have to play with the settings a bit. I'll start off with 2 up front and 8 in rear. Thanks again.
TT
The stiffer you run in the rear is going to promote tire spin. You want softer in the back and stiff up front on an AWD setup. FWD is opposite.
interesting...I'd think going stiffer in the rear would promote less squating which would cause less wheel spin up front (and not to mention less shock on the rear drivetrain). I also see you are running near 11 second times so you no doubt have more experience then I do. So :confused:
I'd soften up the rear on a AWD car a bit.. You just dont want to go crazy like a RWD drag car... If you get some chirp and hop upfront stifen the rear a bit.. That spin, grab, hop stuff is bad for the driveline.
