Devicex
- 656
- 1
- Sep 1, 2002
State College,
Pennsylvania
As I went to pull the axles in order to begin my six bolt swap I ran into some trouble removing the bolt located at the bottom of the shock absorber mount and lower control arm. With the nut removed, rather then turning freely or able to be knocked out, the bolt is stuck fast. When torqued, the rubber mount twists with the bolt. I can't figure out how I'm going to get them out, the axles are hanging as I was able to remove them from the tranny and hub but they are stuck between the lower mount, this goes for both sides. Any ideas as to how I can go about removing these bolts, one has to be replaced as I managed to destroy the threads with a hammer, thanks.
