aftermarket rims, questions
You will need one or the other, preferably both. The stock lug nuts with washers will not center in holes which are probably chamfered for beveled nuts. That might be okay if you are using hub-centric rings which many people think you don't need when using beveled nuts.
if the centerbore on the rims match the one for our vehicle (67.1mm), i can do without the centering rings, correct?
