wheel bearings
Grizzly Racing
151
2
Jul 27, 2002
PA, Pennsylvania
looking for some info here.
i'm looking for any info on replacing wheel bearings. i have a squeeling right rear bearing. i even took the brake off the rear to make sure that wasnt it.......
i cant find any info on this.
also while i'm at it........ is there any special grease you can use to lower the friction...... hoping to get the car to roll easier and faster while i'm at it.
thx
-GR
1g I believe you have to buy the hole hub assembly. The only place I could find them was the dealership. For some reason they had some 1G hubs leftover when they built my car and desided to put them on.
It's in the service manual.
There are part numbers to replace them, searching caps this is what I found (all parts you need as far as I know):
MB393807
MB290175
MB393801
MB290428
MB393803
Redline CV2 should do the trick.
