Will 18x7 and a 45 offset fit?
snox135
678
5
Jun 6, 2002
Southern, Wisconsin
I found a killer deal on the rims I wanted but they are 45 offset. I don't think they will fit but I thought I might as well ask.
I have 18x7.5 wheels w/ 45 mm offset. 235/40/18 tires. 1.5" drop. It rubs on all four tires! Stock offset is 46 mm on the tiny 16" rim with 205 tires. I think you may need a higher offset like 50 mm so the rim is pushed more toward the car.
If anything, you'll want less. 50mm definitely won't fit. Your tire will rub the shocks. 45 will be fine.
Originally posted by ricktsu
I Have 18x8's in a 43mm, its tight, but it clears.....you should be more then fine.
Is this on a 1g or 2g?
FWD or AWD?
Is the car lowered?
What size tires are you running?
Thanks for the info :D
